kitisuru
Posted: Thu Dec 01, 2011 10:15 am Post subject: AC oil filters new old stock what car ar they for? |
Hi,
I have a number of AC filters type FZ3 in a metal canister, but I do not know what they fit, can anybody help identifying them. They need to go to someone who can use them!
Dimensions are: Height 12 cm, diameter 9 cm.
Thank you!
(alt+p)
(alt+p)
(alt+p)
Churchill Johnson
Posted: Thu Dec 01, 2011 11:23 pm Post subject: |
| This looks the type that could be fitted as an after market part of a kit to the old sit up and beg Ford pops. |
Scotty
Posted: Fri Dec 02, 2011 8:06 am Post subject: |
I'm with CJ - looks like Pop / Anglia ones to me.  |
Posted: Fri Dec 02, 2011 6:12 pm Post subject: |
I reckon with that fitting they are by-pass filters, which may or may not be aftermarket. If so they must never be adapted to fit a full flow filter system. _________________ Quote from my late Dad:- You only need a woman and a car and you have all the problems you
kitisuru
Posted: Sat Dec 03, 2011 12:15 pm Post subject: thank you |
| Thank you everybody for your replies, this has helped a lot, hopefully I will be able to find a good home for them now... |
P3steve
Posted: Sat Dec 03, 2011 5:17 pm Post subject: |
They look like the one fitted to my P3 Rover have you got the overall size of them, what are you looking to get for them? _________________ If the world didn't suck we'd all fall off |
kitisuru
Posted: Sat Dec 03, 2011 6:47 pm Post subject: size |
Let me know if it matches! |
Inglewood
Joined: 28 Dec 2010 Posts: 183 Location: Stone, Staffordshire
Posted: Sun Dec 04, 2011 10:24 am Post subject: |
The filter body is typical size/colour of early canister types from AC. However, the connector size is not sufficient to be a full-flow. It is not an engine-mounted unit, it is fitted to the inner wing connected by pipes.
The filter appears to be a by-pass retro fit type with pipe connection to the male thread and a banjo connction to the female thread.
These filters were available in different lengths but the connections were similar. |
kitisuru
Posted: Sun Dec 04, 2011 6:17 pm Post subject: AC catalogue |
| Thanks Mike for suggesting the catalogue on eBay, I asked the seller and this reference is not in it unfortunately.... |
Churchill Johnson
Posted: Sun Dec 11, 2011 11:27 pm Post subject: |
| Tried to do some more checking these filters are not for the Ford pop they use ZR1 same as a standard. |
