jag 420 wing repair sections
drekgranada
PostPosted: Wed Apr 04, 2007 8:31 am    Post subject: jag 420 wing repair sections Reply with quote
is there anybody here that knows of anywhere to get repair sections for a 420 jag???
i have one here that needs two front wing repairs done on it and i will have to chop out a lot of the original wing so to make life easier for myself am looking for these sections!!
also i need su carb gasket sets x2 as the floats are leaking on this at the moment (the gaskets are knackered).......
any ideas would be appreciated ??
thanks del
PostPosted: Wed Apr 04, 2007 8:51 am    Post subject: Reply with quote
I'd imagine that carb bits could be got from Burlen Fuel Systems as they do all the SU stuff I think
hth
drekgranada
PostPosted: Thu Apr 05, 2007 8:52 am    Post subject: Reply with quote
hth
thanks rick....
do they have a website??
del....
PostPosted: Thu Apr 05, 2007 9:09 am    Post subject: Reply with quote
yup
http://www.burlen.co.uk/
drekgranada
PostPosted: Thu Apr 05, 2007 7:58 pm    Post subject: Reply with quote
thankyou rick thats amost helpful sits they have there...cheers del...
john-saab
PostPosted: Fri Apr 06, 2007 10:01 pm    Post subject: Reply with quote
From what you say it sounds like you should try and find a local club and ask the members about a recomended body "specialist"..a very "grey" area. There are plenty of people who say they will repair your car for £XXX but im sure there is someone local who will do the job with care ...for the love of the job!
If you are able to do the job at home then ask on a owners forum who supplies the best panels....there are a lot of shoddy panels made in Eastern Europe, they will look wrong and be made of mashed potato.
I can tell you where NOT to go..a company in Sussex sells REALLY bad panels...but thats another story Mad
drekgranada
PostPosted: Fri Apr 06, 2007 11:00 pm    Post subject: Reply with quote
thankyou for your info john
del......
drekgranada
PostPosted: Fri Apr 06, 2007 11:05 pm    Post subject: Reply with quote
here are a couple of picture of the 420's front drivers wing that needs repairing......
as you can see it needs some work here!!!!!
john-saab
PostPosted: Fri Apr 06, 2007 11:51 pm    Post subject: Reply with quote
It looks like more than the wing that needs work. There will be rot in the front of the sill and thats a bigger issue.
I can't help notice the bubbling and the lack of gap at the bottom front edge of the door. There should be a visable groove between the wing and sill..your car looks like it has been skimmed over and re-sprayed.
If you are sure this is the only work that needs doing then carry on but if this is the general condition of the car i would think again unless you can do all of the work yourself?
Are you still coming down to Southern Classics?
drekgranada
PostPosted: Sat Apr 07, 2007 10:10 pm    Post subject: Reply with quote
hi john thanks for your input i will be repairing the 420 myself now,i have been looking into repair panels and i dont have a kings ransom for them!!
so i will be getting the mig out and takling it myself very soon indeed....
chimpchoker
PostPosted: Sat Apr 21, 2007 6:07 pm    Post subject: Reply with quote
....have you tried sng barretts for the repair panels??
I have a 68 MKii 240 and the bits I needed seemed quite cheap. From the photo's you are probably looking at a door skin and bottom, sill and wing but good luck.
Alan
drekgranada
PostPosted: Thu May 03, 2007 11:29 pm    Post subject: Reply with quote
i have made a repair panel for the jag
please feel free to have a look
i have taken a couple of pics of the panel
and a pic of it fitted into place....
but it will need a good skim of body filler as the wing is at least 20-30ml deep with it already
drekgranada
PostPosted: Tue May 22, 2007 12:49 pm    Post subject: Reply with quote
this is the wing repair after a bit of filling work,its not that good but at least its presentable now!!!!!
PostPosted: Tue May 22, 2007 3:13 pm    Post subject: Reply with quote
looks like you've been very busy!! whats the rest of the car like bodywise?
drekgranada
PostPosted: Tue May 22, 2007 5:01 pm    Post subject: Reply with quote
the rest of the body is a bit rough as well rick!!
but thats down to the owner to sort out in the future!!
he just wanted me to repair the rot on this side for the mot certificate!!
the best thing about this car is the recon engine and new clutch fitted is an original jaguar unit(old stock)
it does drive extremely well for an oldie
del................
