drekgranada Guest
Posted: Wed Apr 04, 2007 8:31 am Post subject: jag 420 wing repair sections |
is there anybody here that knows of anywhere to get repair sections for a 420 jag???
i have one here that needs two front wing repairs done on it and i will have to chop out a lot of the original wing so to make life easier for myself am looking for these sections!!
also i need su carb gasket sets x2 as the floats are leaking on this at the moment (the gaskets are knackered).......
any ideas would be appreciated ??
thanks del |
drekgranada Guest
Posted: Thu Apr 05, 2007 8:52 am Post subject: |
| Rick wrote: | I'd imagine that carb bits could be got from Burlen Fuel Systems as they do all the SU stuff I think
hth
Rick |
thanks rick....
do they have a website??
del.... |
drekgranada Guest
Posted: Thu Apr 05, 2007 7:58 pm Post subject: |
| thankyou rick thats amost helpful sits they have there...cheers del... |
john-saab Guest
Posted: Fri Apr 06, 2007 10:01 pm Post subject: |
From what you say it sounds like you should try and find a local club and ask the members about a recomended body "specialist"..a very "grey" area. There are plenty of people who say they will repair your car for £XXX but im sure there is someone local who will do the job with care ...for the love of the job!
If you are able to do the job at home then ask on a owners forum who supplies the best panels....there are a lot of shoddy panels made in Eastern Europe, they will look wrong and be made of mashed potato.
I can tell you where NOT to go..a company in Sussex sells REALLY bad panels...but thats another story  |
drekgranada Guest
Posted: Fri Apr 06, 2007 11:00 pm Post subject: |
thankyou for your info john
del...... |
drekgranada Guest
Posted: Fri Apr 06, 2007 11:05 pm Post subject: |
here are a couple of picture of the 420's front drivers wing that needs repairing......
as you can see it needs some work here!!!!! |
john-saab Guest
Posted: Fri Apr 06, 2007 11:51 pm Post subject: |
It looks like more than the wing that needs work. There will be rot in the front of the sill and thats a bigger issue.
I can't help notice the bubbling and the lack of gap at the bottom front edge of the door. There should be a visable groove between the wing and sill..your car looks like it has been skimmed over and re-sprayed.
If you are sure this is the only work that needs doing then carry on but if this is the general condition of the car i would think again unless you can do all of the work yourself?
Are you still coming down to Southern Classics? |
drekgranada Guest
Posted: Sat Apr 07, 2007 10:10 pm Post subject: |
hi john thanks for your input i will be repairing the 420 myself now,i have been looking into repair panels and i dont have a kings ransom for them!!
so i will be getting the mig out and takling it myself very soon indeed.... |
chimpchoker Guest
Posted: Sat Apr 21, 2007 6:07 pm Post subject: |
....have you tried sng barretts for the repair panels??
I have a 68 MKii 240 and the bits I needed seemed quite cheap. From the photo's you are probably looking at a door skin and bottom, sill and wing but good luck.
Alan |
drekgranada Guest
Posted: Thu May 03, 2007 11:29 pm Post subject: |
i have made a repair panel for the jag
please feel free to have a look
i have taken a couple of pics of the panel
and a pic of it fitted into place....
but it will need a good skim of body filler as the wing is at least 20-30ml deep with it already
drekgranada Guest
Posted: Tue May 22, 2007 12:49 pm Post subject: |
this is the wing repair after a bit of filling work,its not that good but at least its presentable now!!!!!
drekgranada Guest
Posted: Tue May 22, 2007 5:01 pm Post subject: |
the rest of the body is a bit rough as well rick!!
but thats down to the owner to sort out in the future!!
he just wanted me to repair the rot on this side for the mot certificate!!
the best thing about this car is the recon engine and new clutch fitted is an original jaguar unit(old stock)
it does drive extremely well for an oldie
del................ |
