Oops!
Uncle Joe
PostPosted: Sat May 03, 2008 9:57 am    Post subject: Oops! Reply with quote
I dont think this should look like this, but how it happened is a complete mystery to me. I wonder if anyone can recognise what it was?
Greeney in France
PostPosted: Sat May 03, 2008 10:47 am    Post subject: Reply with quote
Looks like an inner drive shaft bearing?
OR now I have had a second look a gear lever socket
www.OldFrenchCars.com
Uncle Joe
PostPosted: Sat May 03, 2008 12:52 pm    Post subject: Reply with quote
Its neither...the bent bit on the right should be straight....
PostPosted: Sun May 04, 2008 11:00 am    Post subject: Reply with quote
I've never seen one before and it's difficult to gauge its size, but is it the end of a speedo cable?
Uncle Joe
PostPosted: Sun May 04, 2008 11:05 am    Post subject: Reply with quote
Spot on Peter! Its the transmission end of the outer casing.
I still dont know how it got damaged though....
Job-Rated
PostPosted: Sun May 04, 2008 2:12 pm    Post subject: Reply with quote
Drivin' too bloomin' quick, I shouldn't wonder... Laughing Laughing
Uncle Joe
PostPosted: Sun May 04, 2008 2:19 pm    Post subject: Reply with quote
As if I would! Laughing
Brian M
PostPosted: Tue May 06, 2008 2:02 pm    Post subject: Reply with quote
UJ
It is caused either
1. by the "torque twist" on your V8 rotating the gearbox and taking up all the slack in the speedo cable.
2. going over a speed bump too fast and the bulkhead (and therefore dashboard) moving relative to the drivetrain and again the speedo cable having no slack left.
or
3. you hit it with a screwdriver!
Brian
Uncle Joe
PostPosted: Tue May 06, 2008 2:13 pm    Post subject: Reply with quote
Brian, I only wish it was as simple as that. At least then I would know what had happened!
