3/8" UNC bleed nipples
PostPosted: Mon Jul 12, 2010 9:12 am    Post subject: 3/8" UNC bleed nipples Reply with quote
Hi,
We're on the lookout for some of these for the Dodge's wheel cylinders .. can anyone suggest a supplier? I've looked on the Namrick site but can only find 3/8 UNF
traction39
PostPosted: Mon Jul 12, 2010 10:53 am    Post subject: Reply with quote
Just a thought, are you sure that the fittings are UNC and not BSW? I thought UNC and BSW threads matched and made up OK. However, their form is slightly different. Are not 1/2" UNC/BSW the exception 12TPI and 13TPI?
Disclaimer! These are brakes and need to be correct!!!
Alistair
michael1703
PostPosted: Mon Jul 12, 2010 12:14 pm    Post subject: Reply with quote
have you tried automec?
01280 822818
or
past parts
01284 750729
WLC4EVA
PostPosted: Sun Jul 18, 2010 9:34 am    Post subject: Reply with quote
[color=white].
Seems a very odd size.
Have you tried?
speedbleeder@earthlink.net
Kind Regards, WLC
PostPosted: Sun Jul 18, 2010 11:06 am    Post subject: Reply with quote
If you get stuck give me a shout and I can make them for you, I had to make all the bleed screws and cylinder screws for the morris 8 as they are a really odd size (whitworth spanner size with UNF threads!!)
To improve things I made them up in stainless steel.Very Happy
Given the US origins I doubt if the threads would be BSW, although 3/8 BSW & UNC have the same pitch, the angle and depth of the thread are different, so should not be mixed!
PostPosted: Fri Jul 23, 2010 9:44 am    Post subject: Reply with quote
Thanks Dave, I'll see if they've found anything next time I'm over, if not I'll drop you a note.
ta, R
stuchamp
PostPosted: Fri Jul 23, 2010 2:42 pm    Post subject: Reply with quote
I think you've been here before...........
http://www.robertsmotorparts.com/truck_parts.asp?Action=search&c=Trucks+-+Brake+Parts
baconsdozen
PostPosted: Fri Jul 30, 2010 1:50 pm    Post subject: Reply with quote
They are almost certain to be UNC,I doubt if any US made vehicle uses Whit threads anywhere,although I've seen some with odd BA fittings.
As someone else has pointed out the threads are close enough that the bolts can be swapped over but tighteneing them will almost certainly strip the threads.
A decent quality thread gauge is a good investment for anyone messing about with old cars or bikes.
PostPosted: Fri Jul 30, 2010 2:10 pm    Post subject: Reply with quote
Handily the originals have turned up. Thanks stuchamp, I had a look at the Roberts site but whether they're the same items as on the more commonly found (ie 1/2 ton) trucks I'm not sure Confused Anyway, not a problem now Smile
stuchamp
PostPosted: Fri Jul 30, 2010 4:53 pm    Post subject: Reply with quote
Glad you found them. I may actually have a pair here along with the front backing plates, cylinders, etc. Need to dig thru the back shed again.
